*loadtype
Sets the load types to the current global value.
*loadtype config type
HyperMesh Tcl Modify Command
- config
- The load configuration that is to have its type changed. This input can be specified as config number or config string label.
- type
- The type which the configuration should become. This input can be specified as type number or type string label.
To set the type of forces to 2:
*loadtype 1 2
To set the type of forces to MBFRC in OptiStruct user
profile:
*loadtype force MBFRCAfter the type has been set, all loads of the corresponding configuration are set to the value of type.
None.
Version History
2022.3 - Added support for string labels as input arguments.
