*elementsaddnodesfixed
Marks the specified nodes of the old elements as fixed nodes (nodes that must be retained in the mesh to be created) before using the commands for remeshing/meshing by elements.
*elementsaddnodesfixed elements_mark, nodes_mark
HyperMesh Tcl Modify Command
- elements_mark
- The mark of elements that are considered for remeshing/meshing by elements. Valid values are 1 and 2.
- nodes_mark
- The mark of nodes specifying the nodes to be retained in the new mesh. Valid values are 1 and 2.
*createmark elements 1 154 155 158 159 160 161 164 165 339 341 343 345 347
*createmark nodes 2 210 277 370
*elementsaddnodesfixed 1 2
*defaultremeshelems 1 3.0 2 2 0 1 1 1 0 0 0 0 0 30 Using *elementsaddnodesfixed() implies that it will be followed by a command that performs remeshing/meshing by elements. For example, *defaultremeshelems(), *defaultmeshelems(), *interactiveremeshelems(), or *interactivemeshelems(). *createmark() directive is required for this command.
Version History
9.0
