*memberpanelmesh
Meshes memberpanels to create 2D elements.
*memberpanelmesh mark=<mark_id> elemsize=<value> elmetype=<value>
HyperMesh Tcl Modify Command
Meshes selected member panels to create 2D elements.
- mark=<mark_id>
- The ID of the mark containing the memberpanels to mesh. Valid values are 1 and 2.
- elemsize=<value>
- The element size.
- elemtype=<value>
- The element type used for mapped meshing algorithms. Valid values are:
Examples
To mesh displayed memberpanels:
*createmark memberpanels 1 displayed
*memberpanelmesh mark=1 elemsize=10.0 elemtype=1
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2022
