*meshline_update_surface
Creates surfaces on closed meshline loops.
*meshline_update_surface flag reserved
HyperMesh Tcl Modify Command
This command creates surfaces on closed meshline loops.
- flag
- 0 - Disable creating surfaces on closed meshline loops.
- reserved
- Reserved for future use. Must be set to 0.
To turn on creating surfaces for closed meshline loops:
*meshline_update_surface 1 0
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
11.0
