*dynamicrotatemode
Sets mode for output of intermediate rotation commands.
*dynamicrotatemode mode
HyperMesh Tcl Modify Command
- mode
- Set to 1 or 0.
When mode is set to 1, the following output is
generated:
*dynamicviewbegin
*quatrotate -0.00785649346 -5.7397916e-005 0.00228960797 0.999966514
*quatrotate -0.00994070323 0.00170778765 0.0047803938 0.999937705
*quatrotate -0.00529684395 -0.000673180986 0.000802068982 0.999985423
*quatrotate 0.000230328525 0.00100703597 0.00106667981 0.999998898
*quatrotate -0.00263644785 -0.000327769044 0.000395387048 0.999996393
*dynamicviewend When mode is set to 0, the following output is
generated:
*viewset(-0.722177, -0.299006, 0.623743, 0.000000,
0.657815, -0.575689, 0.485656, 0.000000,
0.213868, 0.761037, 0.612440, 0.000000,
-3.756111, 5.964252, -3.030465, 1.000000,
-8.703590, 2.583235, 0.886445, 8.621393)When the mode is set to 1, intermediate *quadrotate() rotation commands are output to the command file. Otherwise, only the final position is output, reducing the size of the command file.
