*edgesuppress
Suppresses the selected edge.
*edgesuppress edge
HyperMesh Tcl Modify Command
- edge
- The edge to suppress.
To suppress edge 5:
*edgesuppress 5 Only face edges which are interior to a surface or shared between two surfaces may be suppressed and unsuppressed. Suppressing an edge can combine two separate surfaces, and removes its affect on the mesh.
