*detach_solids
Separates solids that have shared boundary surfaces.
*detach_solids entity_type mark_id options
HyperMesh Tcl Modify Command
Separates solids that have shared boundary surfaces by duplicating the common surfaces and breaking, when possible, the connectivity between the edges and vertices of shared surfaces.
- entity_type
- Input geometry type. Valid value is solids.
- mark_id
- The ID of the mark of input solids. Valid values are 1 and 2.
- options
- Defines the separation method. Valid values are:
- 0 - Selected solids are separated from those not selected. Shared boundary between selected solids is preserved.
- 1 - Selected solids are separated from each other. Shared boundary between selected solid and those not selected is preserved.
- 2 - Each selected solid is separated from all solids it has a shared boundary with.
- 3 - Same as 0.
Examples
Assume that solids with IDs 1, 2, 3 have shared boundary surfaces between each other.
To separate solids 1 and 2 between each other, but keep solid 3 connected to both solid 1
and solid 2:
*createmark solids 1 1 2
*detach_solids solids 1 1To separate solids 1 and 2 from solid 3 and keep shared boundary between solids 1 and
2:
*detach_solids solids 1 0Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
12.0.110
