*CE_ConnectorCreateByAutoseam
Creates line connectors between the input components.
*CE_ConnectorCreateByAutoseam entity_type mark_id "<option1>=<value1> <option2>=<value2> ... <optionN>=<valueN>"
HyperMesh Tcl Modify Command
This command creates line connectors between the input marked components/parts based on the options you supply as the input. All options are needed as the input for this command to work. This command is also supported for history (undo/redo).
- entity_type
- The type of entity to create connectors between. Valid values are parts and components.
- mark_id
- The mark ID containing the input entities. Valid values are 1 and 2.
- search_radius=<value>
- The distance within which two components/parts should be present to create connectors between them.
- pitch=<value>
- The distance for the distribution of connector test points.
- minimum_connector_length=<value>
- The minimum length required to create a connector. Connectors with a length less than the defined value are not created.
- exclude_holes_with_radius_less_than=<value>
- Holes with a radius less than the defined value are skipped from the connector creation process.
- create_internal_seams=<value>
- Specifies if the connector is to be created within the same component/part. Valid values are 0 and 1.
Examples
To create the connector between components “componentA” and “componentB” with the following
values of the options:
*createmark components 1 "componentA" "componentB"
*CE_ConnectorCreateByAutoseam components 1 "search_radius=10.000000 pitch=10.000000 minimum_connector_length=10.000000 exclude_holes_with_radius_less_than=10.000000 create_internal_seams=1"Errors
None.
Version History
2021.2
