*createfacesonfreeboundaries
Creates face elements on all free solid element boundaries.
HyperMesh Tcl Modify Command
This command is used to find and create shell elements on free boundaries of all the solid elements. This command generates faces only for first order shell elements. It operates on all solid elements, regardless of display status.
Examples
To create faces on free boundaries:
*createfacesonfreeboundariesErrors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
12.0.110
