*toggleincludefromdisplay
Toggles the entities contained in the specified include file to/from the current display.
*toggleincludefromdisplay id shortname
HyperMesh Tcl Modify Command
This command un-displays/masks any entities in the specified include file that are currently displayed and displays/unmasks any entities in the specified include file that are currently hidden. The display of entities not in the specified include is not affected.
- id
- The ID of the include file. An ID of 0 selects the main file. If not specified, should be blank "".
- shortname
- The shortname of the include file. This value can be blank when id is specified. If not specified, should be blank "".
Examples
To toggle the entities in the include with ID 3:
*toggleincludefromdisplay 3 ""
To toggle the entities in the include with shortname elems.fem:
*toggleincludefromdisplay "" elems.fem
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
9.0
