*combineplotels
Creates a line from a group of plot elements.
*combineplotels mark_id
HyperMesh Tcl Modify Command
- mark_id
- The ID of the mark containing the plot elements. Valid values are 1 and 2.
Examples
Combine plotels 1-100:
*createmark elems 1-100
*combineplotels 1Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
