*makesecondarymodeleditable
Sets the editable state of secondary models.
*makesecondarymodeleditable model_name edit_state
HyperMesh Tcl Modify Command
- model_name
- The name of the secondary model.
- edit_state
- 0 - Not editable
Examples
To make the secondary model MyModel editable:
*makesecondarymodeleditable "MyModel" 1
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2020.1
