*sketchdisassociateentities
Removes the association between the sketch and its realized entities.
*sketchdisassociateentities sketch_id
HyperMesh Tcl Modify Command
Removes the association between the sketch and its realized entities. If the sketch entity is hidden, it becomes visible.
- sketch_id
- The ID of the sketch entity.
Examples
To remove the association between sketch ID 1 and its realized
entities:
*sketchdisassociateentities 1Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2021.2
