*createorthotropicdirection
Creates the INSHE/ORTHO_LOC tables based on the composite data in the session.
HyperMesh Tcl Modify Command
None.
To create the INSHE/ORTHO_LOC tables based on the composite data in the session:
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2017.2
