*CE_SetLinkChangeManagerSettings
Modifies/unrealizes/rerealizes connectors when there is change in attribute values or deletion of referenced entities.
*CE_SetLinkChangeManagerSettings perform operation
HyperMesh Tcl Modify Command
- perform
- 0 - Do not perform operation
- operation
- 0 - Modify
Examples
Modify connectors upon
changes:
*CE_SetLinkChangeManagerSettings 1 0Unrealize connectors upon
changes:
*CE_SetLinkChangeManagerSettings 1 1Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2021
