*splitcontactfromcontactgroup
Disassociates a group (contact pair/tie) entity from a contact group.
*splitcontactfromcontactgroup id
HyperMesh Tcl Modify Command
- id
- The ID of the group entity to disassociate.
Examples
To disassociate group 1 from the contact
group:
*splitcontactfromcontactgroup 1Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2020
