*plynormalsdisplay
Controls the display of 2D element ply normals.
*plynormalsdisplay ply_name mark_id size
HyperMesh Tcl Modify Command
- ply_name
- The name of the ply to display normals for.
- mark_id
- The ID of the mark containing the elements whose normals are to be displayed. Valid values are 1 and 2.
- size
- Specifies the size of the graphic normal vector. If set to zero, the vector is drawn at 10% of the screen size.
To turn on the display of normals for elements 1-10 in Ply1, at 10% screen size:
*createmark elems 1 1-10
*plynormalsdisplay Ply1 1 0
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
13.0
