*surfacemarkmerge
Combines the selected surfaces into one surface, and divides the surface along the internal edges that correspond to fillets and feature lines.
*surfacemarkmerge mark breakangle minradius maxradius
HyperMesh Tcl Modify Command
- mark
- The mark ID containing the surfaces.
- breakangle
- The threshold used to recognize feature lines.
- minradius
- The lower limit of the radius of curvature used to recognize fillets.
- maxradius
- The upper limit of the radius of curvature used to recognize fillets.
To combine a surface with a feature breakangle of 30.0 and fillet radii of 1.0 and
15.0:
*createmark surfaces 1 1 31 57 91 93 145 189 190
*surfacemarkmerge 1 30.0 1.0 15.0 The *createmark() command is required. On the Geom Cleanup panel, this command corresponds to the organize by feature tool.
