*adaptive_wrapper_reject_clear
Clears the reject buffer for all *adaptive_wrapper_* commands.
HyperMesh Tcl Modify Command
Examples
#Initialization of wrapper mesh with base mesh
*createmark elements 1 "all"
*adaptive_wrapper_init elements 1 1 0
#Build skeletal octree structure
*adaptive_wrapper_build
#Preview all cavities
*adaptive_wrapper_preview
#Generate Mesh
*createstringarray 2 "DoRemesh: 1" "RemeshGrowthRate: 1.2"
*adaptive_wrapper_mesh 0 1 2
#Clear the reject
#End of wrapper mesh
*adaptive_wrapper_end
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0
