*solidrc_fillhole_nodelist
Creates a patch of elements from a list of nodes.
*solidrc_fillhole_nodelist nodelist_id flag
HyperMesh Tcl Modify Command
This command creates a patch of elements from a list of nodes. Flag determines if HyperMesh or display elements are created.
- nodelist_id
- The ID of the list of nodes.
- flag
- 0 - HyperMesh elements are created.
Examples
To create a patch of display elements using nodes ID 49805, 49806, 49807, 49808, 49809, and
49810:
*createlist nodes 1 49805 49806 49807 49808 49809 49810
*solidrc_fillhole_nodelist 1 2Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2024
