*refineelementsbysize
Refine elements to target element size.
*refineelementsbysize mark maxlength
HyperMesh Tcl Modify Command
- mark
- The ID of the mark which contains the elements to be refined.
- maxlength
- The maximum element edge size.
To refine the elements to target element size:
*createmark elements 1 12 16 106 107 108 109
*refineelementsbysize 1 0.1
*createmark() is required.Errors
None.
