*imprint_mesh
Imprints mesh or geometry onto target mesh or FE geometry surface/lines creating new edges/fixed points or a mesh patch respectively.
*imprint_mesh src_type=<entity_type> src_mark=<mark_id> tgt_type=<entity_type> tgt_mark=<mark_id> ?option1=<value1>? ?option2=<value2>? … ?optionN=<valueN>?
HyperMesh Tcl Modify Command
Imprints source entities (nodes or elements) onto target entities (elements, components, parts or surfaces) with various input options.
- src_type=<entity_type>
- The type of the source entity for imprint. Valid values are nodes, elements, and surfaces. Note that only FE geometry surfaces are supported.
- src_mark=<mark_id>
- The ID of the mark containing the source entities for imprint. This will not be used if source is a node list. Valid values are 1 and 2.
- tgt_type=<entity_type>
- The type of target entity for imprint. Valid values are lines, surfaces, elements, components and parts.
- tgt_mark=<mark_id>
- The ID of the mark containing the target (destination) entities for imprint. Valid values are 1 and 2.
- src_node_list=<value>
- The ID of the list containing the source nodes defining the segments to imprint. Valid values are 1 and 2. This will be passed only if the source is a node list.
- close_node_list=<value>
- This is applicable only if source is a node list.
- anchor_nodes_mark=<value>
- The ID of the mark containing the anchor nodes used for imprint. If provided, these nodes are anchored during imprint/remesh. Valid values are 1 and 2.
- remain=<value>
- 1 - Source remains, source node coordinates are kept. (default)
- projection=<value>
- 0 - Normal to destination. (default)
- projection_vector={x y z}
- The x, y, z components defining the vector direction. Should be defined if projection is set to 2.
- to_dest_component=<value>
- -1 - Create elements in source component.
- do_not_remesh_rebuild_extn=<value>
- 0 – Remesh/rebuild extension. (default)
- do_not_add_fixed_points_edges=<value>
- 0 - Add fixed points/edges on nodes imprint. (default)
- remesh_mode=<value>
- -1 - No remesh. Element connectivity is maintained by recovery of the imprinting element edges.
- remesh_layers=<value>
- Must be defined if remesh_mode is 2.
- angle=<value>
- The angle in degrees used to define feature edges on the mesh. (default 25.0)
- max_distance=<value>
- The command will exit with an error if the distance between source and destination exceeds this value. If not specified, this is ignored.
- mesh_size=<value>
- The mesh size used for remeshing the imprint area. Automatically detected from input mesh if not provided.
- mesh_type=<value>
- The mesh type used for remeshing the imprint area. Automatically detected from input mesh if not provided.
Examples
To imprint elements ID 217 to 232 onto elements ID 117 to 216, imprinting along direction (0, 0, -1), creating a patch, with destination component as source component, remesh rebuild extension as 1, add fixed points edges as 0, without anchor nodes, remesh mode as 0 and a feature angle of 30:
*createmark elems 1 217-232
*createmark elems 2 117-216
*imprint_mesh src_type=2 src_mark=1 tgt_type=2 tgt_mark=2 projection=1 projection_vector={0 0 -1} remain=4 to_dest_component=-1 do_not_remesh_rebuild_extn=1 do_not_add_fixed_points_edges=0 anchor_nodes_mark=0 remesh_mode=0 angle=30.0
# Handle error
}Version History
2023
