*surfaceintersectmark
Creates lines by intersecting surfaces with a plane or other surfaces.
*surfaceintersectmark mark_id1 plane_flag plane_id mark_id2
HyperMesh Tcl Modify Command
Creates lines by intersecting surfaces with a plane or other surfaces. The line segments are organized into the current component.
- mark_id
- The mark ID containing the surfaces to intersect. Valid values are 1 and 2.
- plane_flag
- 0 - Use mark_id2 to define the surfaces to use for the intersection.
- plane_id
- The ID of the plane to use for the intersection, if plane_flag is 1. This is defined using the *createplane command.
- mark_id2
- The ID of the mark containing the surfaces to use for the intersection, if plane_flag is 0. Valid values are 1 and 2.
Examples
To create intersection lines for the xy-plane with a base node of 0, 10, 0 with the
displayed
surfaces:
*createmark surfaces 1 displayed
*createplane 1 0 0 1 0 10 0
*surfaceintersectmark 1 0 1 To create intersection lines for the intersection of surfaces 1 and 2 with surfaces 10 and
11:
*createmark surfaces 1 1 2
*createmark surfaces 2 10 11
*surfaceintersectmark 1 1 1 2Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
