*setcurrentmodel
Sets the specified model as current.
*setcurrentmodel name
HyperMesh Tcl Modify Command
- name
- The name of the model to set current.
Examples
To set model named model-2 as current:
*setcurrentmodel model-2Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2019
