*elementqualityswapedgenew
Switches the connectivity of the two elements that share the specified edge to the next legal configuration.
*elementqualityswapedgenew element_id edge_index
HyperMesh Tcl Modify Command
This command switches the connectivity of the two elements that share the specified edge to the next legal configuration.
This command only functions between an *elementqualitysetup command and an *elementqualityshutdown command.
- element_id
- The element ID.
- edge_index
- The index of the edge to swap, starting from 0.
To swap elements 27 edge 3, 22 edge 0, 21 edge 2 and 26 edge
1:
*createmark elems 1 displayed
*elementqualitysetup 1
*elementqualityswapedgenew 27 3
*elementqualityswapedgenew 22 0
*elementqualityswapedgenew 21 2
*elementqualityswapedgenew 26 1
*elementqualityshutdown 1Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
12.0.110
