*setreviewbymarkenhanced
Adds entities to the enhanced review list based on a mark.
*setreviewbymarkenhanced entity_type mark_id color shaded edges
HyperMesh Tcl Modify Command
This command adds entities to the enhanced review list based on a mark. This is similar to *setreviewbymark, but allows for entity shading and edge visualization.
- entity_type
- The type of entity to add to the review list. Valid values are:
- nodes
- elems
- points
- lines
- surfs
- solids
- connectors
- loads
- equations
- systs
- vectors
- mark_id
- The ID of the mark containing the entities. Valid values are 1 and 2.
- color
- The color to use for review of the entity. Valid values are 1-64.
- shaded
- If set to 1, surfaces and elements are put into shaded mode.
- edges
- If set to 1, surface and element edges are drawn in black.
To review elements 1-100 with color 4 and enabling shading and edge visualization, with all other non-reviewed entities having transparency and gray color:
*createmark elems 1 1-100
*setreviewbymarkenhanced elems 1 4 1 1
*setreviewcolormode 0
*setreviewtransparentmode 1
*setreviewmode 1
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
11.0.130
