*AE_ConvertBoltLinkToAttachment
Converts connector bolt comp/part links to attachment links.
*AE_ConvertBoltLinkToAttachment mark_id
HyperMesh Tcl Modify Command
Converts connector bolt comp/part links to attachment links. New attachments are created as needed.
- mark_id
- The ID of the mark of connectors to convert. Valid values are 1 and 2.
Examples
Convert all bolt connectors to bolt connectors with attachments as links:
*createmark connectors 1 all
*AE_ConvertBoltLinkToAttachment 1
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2020
