*equationupdatemeshconnectivity
Updates MPC equation connectivity.
*equationupdatemeshconnectivity mark_id tolerance
HyperMesh Tcl Modify Command
Updates MPC equation connectivity. It updates the independent/dependent nodes to the nearest nodes within the specified tolerance, if the independent/dependent nodes are not connected to any elements.
- mark_id
- The mark ID containing the equations. Valid values are 1 and 2.
- tolerance
- The tolerance to use when finding the nearest nodes to connect to.
To update the mesh connectivity of equation 1 and 3 using a tolerance of
10:
*createmark equations 1 1 2 3
*equationupdatemeshconnectivity 1 10Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0
