*updatefree1delements
Updates rigidlink and RBE3 elements to remove free legs and optionally update the weights.
*updatefree1delements input_mark_id output_mark_id update_weight summary_filename
HyperMesh Tcl Modify Command
Updates rigidlink and RBE3 elements to remove free legs and optionally update the weights. If all legs of the rigidlink or RBE3 are free, the element is deleted.
- input_mark_id
- The ID of the mark containing the rigidlink and RBE3 elements to consider. Valid values are 1 and 2.
- output_mark_id
- The ID of the mark containing any elements that have been modified. Valid values are 1 and 2.
- update_weight
- Flag to determine whether to update leg weights to 1.0. Valid values are:
- summary_filename (optional)
- Log file to output, containing a summary of what was modified. If not needed, use "". Otherwise, the full path and file name must be specified.
To update all displayed elements, with the affected elements going to mark 2, without
updating the weights, and write the summary to
C:/summary.txt.
*createmark elems 1 displayed
*updatefree1delements 1 2 0 C:/summary.txtErrors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
11.0
