*entitybundleregister
Defines a name and signature for a new entity bundle.
*entitybundleregister name entity_type_list also_delete_instance
HyperMesh Tcl Modify Command
In that case, you would usually use also_delete_instance to additionally discard that data saved with that bundle name. It is not necessary to discard the data. You could have the bundle registered and active only while a particular dialog or browser is displayed and unregister the definition whenever it is not displayed, but let the data persist between uses.
- name
- The name to use for the entity bundle. If the name is already in use, this overwrites the prior definition.
- entity_type_list
- The signature to use for the data of the entity bundle. This is a list of entity type names (for example, "components materials elements") with each item being a list of entities of those particular entity types. A maximum of 10 entity types can be provided.
- also_delete_instance
- If entity_type_list is empty, any data associated with that definition may be kept in the database for future use.
Examples
To define a new of bundle named "compbundle" having 2 data
items:
*entitybundleregister "compbundle" "components components" 1To discard the bundle definition for "compbundle" and any data that may have been
associated with it:
*entitybundleregister "compbundle" "" 1Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
14.0.130
