*blmesh2d_mc
Imprints edge layers on a surface mesh based on parameters defined in the edge layer control.
*blmesh2d_mc mark_id
HyperMesh Tcl Modify Command
Imprints edge layers on a surface mesh based on parameters defined in the edge layer control. Only the active edge layer control is utilized for imprinting. Input surfaces in mesh controls should have an associated mesh.
- mark_id
- The ID of the mark containing mesh controls. Valid values are 1 and 2.
Examples
To imprint edge layers using all mesh controls in the
model:
*createmark meshcontrols 1 all
*blmesh2d_mc 1Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2021.2
