*readnodepositionsfromdynainfile
Moves nodes in the current model to positions given in a dynain file.
*readnodepositionsfromdynainfile path options
HyperMesh Tcl Modify Command
Moves nodes in the current model to positions given in a dynain file. Optionally, initial stress of elements may be read.
A valid LS-DYNA model must be loaded.
- path
- The full path and file name of the dynain file.
- options
- A string list of options that define which cards to read. The string may include initial_stress_beam initial_stress_shell and initial_stress_solid.
To read node positions from
C:/Users/default/dynain:
*readnodepositionsfromdynainfile "C:/Users/default/dynain"To read node positions and initial_stress_solid from
*readnodepositionsfromdynainfile "C:/Users/default/dynain" "initial_stress_solid"To read node positions and all initial_stress cards from
*readnodepositionsfromdynainfile "C:/Users/default/dynain" "initial_stress_beam initial_stress_shell initial_stress_solid"Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2017.1
