*morphmaptonodesnodelistoffset
Maps a node list to a line along a vector.
*morphmaptonodesnodelistoffset list_id_nodes entity_type_handles mark_id_handles node_list_id use_symmetry use_constraints project vector_id offset
HyperMesh Tcl Modify Command
Maps nodes to, or offset from, a specified line using the temporary shape created by *morphmaptshp and *morphmaptshpedge as a guide. Selected handles can optionally follow behind the morphing operation.
Nodes can be projected on to the line along a vector, normal to the line, or spaced evenly along the line (if the nodes belong to edge domains).
In the map to geom tool, the line used in this command is created from a node list.
- list_id_nodes
- The ID of the list containing the input nodes. Valid values are 1 and 2.
- entity_type_handles
- Must be set to handles.
- mark_id_handles
- The ID of the mark containing the handles. Valid values are 1 and 2.
- node_list_id
- The ID of the list containing the target nodes. Valid values are 1 and 2.
- use_symmetry
- 0 - Do not use symmetry (only option)
- use_constraints
- 0 - Do not use constraints
- project
- 0 or 10 - Project along vector defined by vector_id
- vector_id
- The ID of vector created using *createvector for the projection direction. Must be set to 1.
- offset
- The distance to offset nodes from the target. Not used if project is 2.
To project nodes on list 1 normal to a line with ID 23 with an offset of 1.2:
*morphmaptonodesnodelistoffset 1 handles 1 23 0 1 1 1 1.2
# Handle error
}Version History
2020.1
