*CE_FE_Register
Registers pre-existing FE to a single connector ID.
*CE_FE_Register id testpoint_index entity_type_string_array number_of_entity_types id_integer_array number_of_ids
HyperMesh Tcl Modify Command
Registers pre-existing FE to a single connector ID. Successfully registering pre-existing FE forces a connector to its realized state.
To use this command, a connector must be in user control mode. Also, note that a single FE entity can be registered with, at most, a single connector. Any FE registered with a given connector is treated as part of that connector’s realization.
- id
- The ID of the connector to register to.
- testpoint_idx
- The connector sub-index in which to register this FE. A connector line with a density of three has three sub-indices (0-2), and a connector point has a single sub-index (0).
- entity_type_string_array
- The ID of the string array that contains the additional entity type names. The string array is created using the *createstringarray command. This should always be set to 1.
- number_of_entity_types
- Integer indicating the size (number of strings) in the string array created using *createstringarray.
- id_integer_array
- The ID of the integer array that contains the entity IDs. The integer array is created using the *createarray command. This should always be set to 1.
- number_of_ids
- Integer indicating the size (number of integers) in the integer array created using *createarray.
Examples
First, change connector 7 to the user control
mode:
*CE_SetSpecificDetailById 7 2 1 0.0Second, create the necessary
arrays:
*createstringarray 3 "systems" "elements" "systems"
*createarray 3 30 2127 31Third, call the CE_FE_Register function for connector
7:
*CE_FE_Register 7 0 1 3 1 3Finally, turn the user control mode off for connector 7
(optional):
*CE_SetSpecificDetailById 7 2 0 0.0Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
