*reflectmark
Reflects a selection of entities about a plane.
*reflectmark entity_type mark_id plane_id
HyperMesh Tcl Modify Command
This command reflects a selection of entities about a plane.
- entity_type
- Type of entity to reflect.
- mark_id
- The ID of the mark containing the entities. Valid values are 1 and 2.
- plane_id
- The ID of the plane to use for the reflection. This is defined using the *createplane command.
To reflect element 15 about a plane normal to the x-axis with its base at the
origin:
*createplane 1 1.0 0.0 0.0 0.0 0.0 0.0
*createmark elems 1 15
*reflectmark elems 1 1Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
