*solidmap_set_source_size
Sets the source 2D mesh size for the next call to *solidmap_end.
*solidmap_set_source_size size
HyperMesh Tcl Modify Command
Sets the source 2D mesh size for the next call to *solidmap_end. This allows setting the along size (density) and the source size independently. The command applies only the next call to *solidmap_end. If this command is not called before *solidmap_end, the value of the source size to set to the same as the along size.
- size
- The solid map source size.
Examples
To set the solid map source size to
1.5:
*solidmap_set_source_size 1.5Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2020
