*ossmooth_savesurf
Exports the final design geometry from OptiStruct topology, topography and shape optimization results.
*ossmooth_savesurf mode filepath units output
HyperMesh Tcl Modify Command
- mode
- 0 - Create .oss file only to be used in standalone version (do not execute OSSmooth)
- filepath
- The full name and path of the OptiStruct .fem results file generated from the optimization.
- units
- Units used for IGES and STEP output. Valid values are:
- 1 - inch
- 2 - mm
- 4 - foot
- 6 - meter
- 10 - cm
- output
- 1 -Nastran
To execute OSSmooth to save surfaces to STEP file C:/test/os1.step, using mm as units:
*ossmooth_savesurf 2 C:/test/os1.fem 2 5
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
12.0
