*configedit
Changes the configuration of a selection of elements.
*configedit mark_id config
HyperMesh Tcl Modify Command
- mark_id
- The ID of the mark. Valid values are 1 and 2.
- config
- The new configuration name to assign. The new configuration cannot add new nodes.
Examples
To set all plot elements to
bar2:
*createmark elements 1 "by config" plot
*configedit 1 bar2Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
