*filtertable
Filter unique cells of key strings of selected column(s) and generate a new table considering the indices of key strings in key columns.
*filtertable table=<name> keystring=<string1, string2, ... stringN> keycolumns=<column1, column2, ... columnN> valuecolumns=<column1, column2, ... columnN> targettable=<name>
HyperMesh Tcl Modify Command
Unless otherwise noted, all inputs are mandatory. They may be specified in any order.
- keycolumns=<column1, column2, ... columnN>
- The key columns of the selected table, separated by commas. These must follow the same sequence as the keystrings.
- keystring=<string1, string2, ... stringN>
- The key strings of the selected columns, separated by commas. These must follow the same sequence as the keycolumns.
- table=<name>
- The name of the input/source table.
- targettable=<name>
- The name of the output/target table.
- valuecolumns=<column1, column2, ... columnN>
- The value columns of the selected table, separated by commas. These must follow the same sequence as the keystrings.
Examples
For a given sourcetable table, filter 2 from layerindex column, 2_3_0 from loadcase column
and get elementid and TAU12 columns output to a new table named
targTable:
*filtertable table=sourcetable keystring={2,2_3_0} keycolumns={layerindex,loadcase} valuecolumns={elementid,TAU12} targettable=targTableErrors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2020
