*solidmap_solids_begin
Starts a multiple-solid solidmap command block.
*solidmap_solids_begin mark_id options elem_size
HyperMesh Tcl Modify Command
This command is used by the multi-solid mapping algorithm to indicate the beginning of a solid mapping command block. It must be paired with a *solidmap_solids_end command.
The commands below can appear in a multi-solids solidmap command block between
*solidmap_solids_begin and
*solidmap_solids_end:
*solidmap_solids_set_density
*solidmap_solids_set_elemsize
*solidmap_solids_set_face_params
*solidmap_solids_set_mapfaceInputs
- mark_id
- ID of the mark containing the solids to mesh. Valid values are 1 and 2.
- options
- Flags that indicate different options for solid mapping. Bit values are used and the
value is a sum of all the options. Any bits not listed below are unused or for internal
use (for example, called in other commands) and are always internally set to their
required values. Setting them to 0 is recommended, but not mandatory.
- Bit0
- 0 - Reserved, must be set to 0.
- Bit1
- 0 - New elems are organized to the solid component.
- Bit2
- Bit3
- 0 - Create elems when calling *solidmap_solids_end .
- Bit4
- 0 - Create layered solid elements.
- Bit5,6
- 0 - Auto decide
- Bit8
- 0 - No additional smoothing steps will occur.
- Bit9,10,11
- 2D elem type 1 and 2 passing to the internal call to
*defaultremesh when per face meshing parameters are not available:
- 0 - Tria
- 512 - Quad
- 1024 - Mixed
- 1536 - R-tria
- 2048 - Quad only
- Bit13
- 0 - Keep shell meshes on input geometry.
- Bit14
- 0 - Normal meshing situations.
- Bit15
- 0 - Do not use meshing parameters saved to the solid map attributes on the geometry.
- Bit16
- 0 - Make the reparameterization of along faces more orthogonal.
- Bit17
- 0 - Do not use per edge/face saved meshing parameters.
- Bit18
- 0 - Stop meshing when elems with negative Jacobian are generated.
- elem_size
- The default element size used when the per edge/face meshing parameters are not available.
To mesh solids 32 and 41 with a default elem size of 2.0 except on edges 2 and 4 which
should have an elem size of 1.0:
*createmark solids 1 32 41
*solidmap_solids_begin 1 0 2.0
*createmark lines 1 2 4
*solidmap_solids_set_elemsize 1 1.0
*solidmap_solids_endErrors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
10.0
