*pointcreateatnodemark
Creates free points at the same locations as the nodes placed on input mark.
*pointcreateatnodemark mark_id
HyperMesh Tcl Modify Command
The command creates free points at locations specified by nodes. The only argument is: mark_id.
- mark_id
- The ID of the mark containing the input nodes. This is mandatory.
Examples
To create free points at the location of the nodes ID 123 and
45:
*createmark nodes 1 123 45
*pointcreateatnodemark 1Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2022.3
