*hwCfdSceneShowHideIsolateEntity
Manages the display of a mark of entities.
*hwCfdSceneShowHideIsolateEntity function entity_type mark_id ?consider_geom? ?consider_elems? ?unhighlight?
HyperMesh Tcl Modify Command
This command is used to manage the display of a mark of entities with an additional ability to show/hide the surfaces attached to the solid.
This should be used in conjunction with the *hwCfdSceneReverseAll and *hwCfdSceneShowAll commands.
This command is valid only for the CFD profile.
- function
- The string defining the operation to be performed on the mark of supported entities. Valid values are:
- entity_type
- The type of entity to modify. Valid values are modules, regions, surfaces and solids.
- consider_geom
- 0 - Do not consider the associated geometry
- consider_elems
- 0 - Do not consider the associated elements
- unhighlight
- 0 - Do not remove highlighting
Examples
To hide surfaces 1-10, reverse the display, then show all entities:
*createmark surfaces 1 1-10
*hwCfdSceneShowHideIsolateEntity hide surfaces 1 1 1 1
*hwCfdSceneReverseAll surfaces 1 1
*hwCfdSceneShowAll 1 1
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2019
