*CE_DetailsCopy
Copy realization details from a connector to a list of connectors.
*CE_DetailsCopy id mark_id reserved
HyperMesh Tcl Modify Command
- id
- The ID of the connector to copy from.
- mark_id
- The ID of the mark of connectors to copy to. Valid values are 1 and 2.
- reserved
- Reserved for future use. Must be set to 0.
Examples
To copy realization details from connector 1001 to connectors 1002, 1003, 1004:
*createmark connectors 1 1002 1003 1004
*CE_DetailsCopy 1001 1 0
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2019
