*delaunay_2d_3d
Performs 2D/3D triangulation of selected nodes.
*delaunay_2d_3d type entity_type mark_id reserved
HyperMesh Tcl Modify Command
- type
- The type of triangulation to perform.
- entity_type
- Must be set to nodes.
- mark_id
- The ID of the mark containing the input entities. Valid values are 1 and 2.
- reserved
- Reserved for future use. Must be set as "".
Examples
To 2D triangulate the displayed nodes:
*createmark nodes 1 displayed
*delaunay_2d_3d 2 nodes 1 ""
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2019
