*complexanimatemodal
Creates a complex modal animation from results data.
*complexanimatemodal title max_deflection frames display_mode
HyperMesh Tcl Modify Command
Creates a complex modal animation from results data. The results file must be loaded before executing this command. The *freesimulation command clears the animation.
- title
- The title to use for the animation.
- max_deflection
- The maximum deflection in model units, or the scale factor, to which the maximum analysis result should be scaled. Use a negative value for model units and a positive value for scale factor.
- frames
- The number of frames to use during the animation sequence. The maximum value is machine dependent.
- display_mode
- Display type to generate. Valid values are:
- 0 - mesh wireframe only
- 1 - rendered with mesh lines
- 2 - feature lines only
- 3 - rendered with feature lines
- 4 - rendered only
Examples
To load the result file named C:/my_results/test.res and generate a
rendered animation for Subcase 1 with Displacements (c) data type, using a 10.0 model unit
scaling:
*analysisfileset C:/my_results/test.res
*inputsimulation "Subcase 1" "Displacements (c)"
*animatecycles 10
*complexanimatemodal "" 10.0 4
*freesimulationErrors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
