*CE_SetGlobalSharedEntitySettings
Set the global shared entity management settings.
*CE_SetGlobalSharedEntitySettings setting value
HyperMesh Tcl Modify Command
- setting
- The name of the setting to update.
- auto_register
- Auto-register shared entities to the connectors during connector realization, HM binary import, solver deck import and FE absorb.
- sharedent_cleanup_delete
- Cleanup shared entities during connector+FE deletion.
- sharedent_cleanup_unrealize
- Cleanup shared entities during connector unrealization.
- value
- 0 - Turn off
- 1 - Turn on
To turn on auto-registration:
*CE_SetGlobalSharedEntitySettings "auto_register" 1
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2017.1
