*removeview
Deletes a saved view from the database.
*removeview name
HyperMesh Tcl Modify Command
- name
- The name of the view to delete. The view names 1-5 are reserved and cannot be deleted.
To delete the view with the name "my_view":
*removeview "my_view"
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
9.0
