*movesolvermasses
Moves the child solvermasses from one parent solvermass to another parent solvermass.
*movesolvermasses solvermass_mark_id target_solvermass_id
HyperMesh Tcl Modify Command
Moves the child solvermasses with config 101 from one parent to another parent solvermass with config 105. Parent solvermass with config 105 can also be put into the source_mark_id. In such case all child in the parent entity will be moved to a new parent.
- solvermass_mark_id
- The ID of the mark containing solvermasses. Valid values are 1 and 2.
- target_solvermass_id
- The ID of the target solvermass.
Examples
To move child solvermasses with ID 1 to 5 from old parent to new parent solvermass ID 6:
*createmark solvermasses 1 1-5
*movesolvermasses 1 6
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2022
