*midsurface_remove_plate_base_conflicts
Removes conflicts between base surface information and planar or sweep plate information on all surfaces by changing the type of all relevant planar and sweep plates into offset plates.
*midsurface_remove_plate_base_conflicts reserved1 reserved2 reserved3 reserved4
HyperMesh Tcl Modify Command
If a surface is marked both as a base surface and as part of a planar or sweep plate, there is a conflict about how to create the corresponding midsurface. On one hand, it is marked to be base surface, which means the corresponding midsurface should be created by offset with a user-specified distance. On the other hand, it is marked as part of a planar or sweep plate, which means the corresponding midsurface should be inserted in the middle of the plate in a form of a piece of plane or sweep surface. These often contradict each other as only offset plates can contain base surfaces.
- reserved1
- Reserved for future use. Must be set to 0.
- reserved2
- reserved3
- reserved4
To turn all planar and sweep plates that contain base surfaces into offset plates:
*midsurface_remove_plate_base_conflicts 0 0 0 0
# Handle error
}Version History
2017.1
