*aic_classify
Classifies selected parts by predicting their label and creating part sets.
*aic_classify classifier trained_file_name mark_id certainty_ratio
HyperMesh Tcl Modify Command
This command classifies parts by predicting their label and creating part sets. Labels are assigned to all parts selected for classification even if some of them have no obvious similarities to the original manually assigned label contents used for training.
- classifier
- The name of the classifier, that is, the name of the folder containing the file defined in trained_file_name.
- trained_file_name
- The trained model, that is, the file containing the training data.
- mark_id
- The ID of the mark containing the part entities to be classified. Valid values are 1 and 2.
- certainty_ratio
- Valid values between 0 and 1. Default is 0.8.
Examples
To classify parts ID 104, 152, and 1858 using the CarDemo classifier and CarDemo_1.aic
trained model:
*createmark parts 1 104 152 1858
*aic_classify CarDemo "CarDemo_1.aic" 1Errors
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
}Version History
2025
